You need to remove enough inner fender bolts to gain access to the fan from the underside.
Thanks for your quick reply. Now a question about the wiring that goes to the blower motor. First of all the motor does not work but the connections via the fusable link into the relay and out of the relay to the fan motor appear to there (purple and black) and are routed out of site under the AC box. That's the reason for the first question, I needed access to check these connections. Late yesterday I found a bare 14 gage (orange) wire down behind the engine, not connected to anything. In looking at the Service Manual it looks like this is also connected to the blower motor having originated from the "heater resistor" and "heater conn" under the dash. Can anyone verify this for me. Thanks!!
The orange wire behind the engine is the heater blower wire for cars without A/C. It is taped and unused on cars with A/C. On cars with A/C, power for the blower comes from the A/C wiring harness. The A/C harness is added to cars with factory A/C.
My service manual shows the same as yours. The A/C harness is not in the manual.
