hello copper top im sure you have many people who need your help worse than mine i like to thanks you for your time and knowledge to get me thru this wierd time talk again thanks
NO, the double contact switch is for the driver's side and the single for the passenger side.I understand the double terminal should be on the right side or pass side, and signal terminal switch on drivers side.
The left side switch does not get power from anywhere. It connects a GROUND that either the domelight circuit needs or the key buzzer circuit needs.hi jim where does the left side switch wire for dome light get its power from thanks again..
I don't mind helping when I can and sometimes too, I get things wrong but hopefully if things are kept correct, others that may come across this discussion may find it helpful to correct an issue they have.jim im happy you have taken the time to help, im 72 still doing cars since 13 and 25 classic cars later, just sometimes the memory goes and a good shot of info is what i need. im glad you took the time to help....
