my chevelle ss is a 1970 non tilt column, hey guys ty so much... but i like to repeat my issue im in the car no buzzer i pull key no buzzer, open the door buzzing, close door buzzing off. making me nuts lol can this be right thanks again lou...
Ok, your posts are a little difficult to read
.... I based my response on your first post.
If the buzzer STOPS when the door is closed, then the door pin switch is okay. This would make the internal switch in the column suspect
if I'm reading your latest post correctly
This is how it is supposed to work:
Car off, key inserted in the ignition and the ignition is in the "off/lock" position. Open driver's side door.....BUZZZZZ. Remove Key. Buzz STOPS.
Car off, key inserted in the ignition and the ignition is in the "off/lock" position. Open driver's side door.....BUZZZZZ. Keep the key inserted, but SHUT THE DOOR. Buzz STOPS.
Key in the "ACCESSORY" position. Open driver's side door. BUZZZZZZZ..
Key in the ON/RUN position. Open driver's side door. NO buzz.
If you want a quick disable method. Disconnect the pink with black stripe wire at the horn relay.
If you want the system to work, you're going to have to do some troubleshooting. We can help, but I'm not going to type it all out if your intent is just to get rid of of the buzz.
