1968 El Camino, 327, M20, 'Glass tilt front, Jag IRS....
According to the numbers I decoded from the 1970 350 I just bought it should be "300 HP" and 10.25-1 compression.
It appears to have been rebuilt once, but the block was not decked.
Came out of a Nova that had a few goodies, headers, "Thunder series" double pumper, Torker II manifold, vacuum can, MSD pro-billet distributor & MSD "Blaster SS" Coil.
Since I never took the heads off I have to wonder if the compression might be even higher?
Disappointed I was not able to spec out the cam too.
Looked at the lobes as best I could while the pan was off, looks fairly mild to me.
From what I could see the pistons look very clean, cross-hatch still visible in the lower cylinders.
Only reason I had anything off was to fix oil leaks.
The guy I got the engine from is not the guy who rebuilt it.
I did hear it run briefly before purchase, sounded fairly mild, maybe a little lope.
My main concern now is what ignition timing to start with, and what octane fuel to use?
Putting an Edelbrock Performer and Q-Jet on in place of the Torker II and double pumper.
Trans is a built Turbo 400 with shift kit, 3:73 rear as I recall.
Anything else I am missing and should be concerned with here?
