1 - 14 of 14 Posts
I'd like a complete original (untouched) one. What are you looking for it?
As far as numbers ... there's a 2-letter code by the carb #, that actually describes which car it goes to. I think what you're describing is 7029207? That same carb goes on Camaro, Chevelle, Nova, etc. The 2-letter code would match the build sheet and model of car.
There's also a date code underneath the carb #. Typically a 4-number Julian style. First 3 numbers are day of the year, last digit is the year.
FYI, 90% of the one's I look at are service replacement carbs. Easiest way to tell is the date code ... they obviously didn't produce a '69 model carb, in a year ending in 1, 2, 3, etc!
Another one (I can't seem to prove it), but all original carbs I've seen do not have the "70" in the carb #. They would simply be stamped 29207, etc.
IM me a price if you looking to sell though. Hopefully I've given you some insightful information into Q'Jets.
Neal
My Delco Rochester book shows that number to be for a 325 HP.
No 350 HP listed that I can find.
Dean, ya sure? I don't have my stuff in front of me ... but I thought 7029201 was a 325HP, and 7029215 for 350HP (both MT)?
I have been looking ... has anyone ever put together a cross-reference of the 2-letter codes? They'd be the same code as on a Build Sheet, but I can't find any 300HP build sheets to reference.
Thanks, Neal
Thanks, Neal
FWIW, the factory Q-Jet on my 390/427 '69 Vette is 7029201 - 4 sp car.
Odd numbers at the end of the part # rep. a MT. Even numbers are Autos.
Yeah ... told Mike, I made it home, and I was wrong. I think 7029207 is a replacement 350ci Vette carb. I was thinking the other models shared the same carb # for that one, but they're all listed under 7029203. Sorry for any confusion.
I am still curious ... has anybody ever put together a matrix of all the 2-letter codes to know what model a particular carb goes to?
Neal
Neal
Here is some help on 69 Q-Jets. It does get involved so if you end up not understanding, please ask again and I will try to clear it up.
There are two manufacturers of Q-Jets. Both Rochester and Carter made them. Each has its own unique stamp and dating type. I will begin with the Carter, as it is the easiest. I will stay with 69 year info as this is the year in question.
All 69 Carter produced carbs are dated with a two line stamp. Number starts at the top of center body and is stamped vertically on the pad. it is then followed on the same line by the two letter assembly, or build sheet code. This is what would appear on a build sheet, and was used to choose the correct carb. The date on Carter Q-Jets was two digits on the next line below the part number. It was a month and year only, A-M for month (Skip I's), and single number for year, in this case, 8 or 9. I have yet to see a #7029207 as a Carter carb, but they are common in other 69 Q-Jets.
Rochester Carbs were definately in transition this year, and used three different types of stamps.
1) Early year Rochester Q-Jets used the whole number stamped in one line including the build sheet code. The #70 was definately used. Number started at bottom of center body. Dates were stamped on the base on the side just behind the secondary throttle shaft on the drivers side. Dating was four digit Julian Date (ex: 3658= 365th Day of 1968) We have also found many of these early types of carbs with no dates on base and believe them to be real. Seem to be on cars between Nov-Jan, but for ovious reasons, cannot confirm starting and ending date of undated carbs. I believe the latest base dated carb I have had was about the end of the year 68.
2) Later 69 Rochester Q-Jets are dated all in one line, and the number, build sheet code and date are all on the vertical pad. Same type of dating as before, and because there was now more info, the 70 was left off as Neal reported. Earliest one I have seen with this type of stamp was 3638, but again, I cannot confirm when it started, and some overlap with the earlier numbering type is possible. This type extended into early 1970 production, when a two line stamp replaced it, which was similar to the Carter type.
3) There is an extremely rare mid year stamp, seems to have been used from late Jan, thru Feb. I cannot again confirm starting and ending dates on this type. It was a real small print with all info on one line and the full part number used. Fonts were about half the size of the normal Q-Jet numbers. I have had these in #7029207, #7029203, and #7029201 and #7029215.
By the way, the Corvette lists the #7029204 for 390HP AT, and #7029215 for 390HP Man. The #7029200 & #7029201 are for 325 HP Chevelle/Camaro/ and have Full size and Nova use, but not Corvette. The #7029207 mentioned in this thread is Corvette 350 350HP. Do not listen to applications listing this for Chevelles, they are wrong. Chevelles used a 300HP motor with the #7029202 on At, and #7029203 on 4spd. Also, as Neal said, the #7029207 was used for many years as a service unit, and sold over the parts counter. It is probably the most common service carb ever made, as they would make only one number, and use it to replace #7029202, and #7029203, etc. Did not matter as much, since it was a replacement. Also, these exist with dates in 78 and 79, and will have a date that will fool you into thinking they are 68 or 69, since they end in 8 or 9. At this point, one must know various features about the carb that ID it to tell the difference. Dead givaway is if it has a pad on center body to mount an idle stop solenoid. 69 carbs did not have this pad. Also, they made this carb in 80's and 90's, since it was one used in NHRA approved racing. 80's up #7029207 carbs have a number of #07029207. I can almost assure you 99.9% of the #9207 Q-Jets you will find are service. I have only ever had 5 production ones in 20 years!!!!!
Hope this helps you guys decode your carbs.
Jeff Dotterer
Dated Components
Diamond Restored Judge
Neal
The build sheet codes are different for each number carb. Does not really tell you what model it fit. Just I.D'd that particular carb for use on the car. The real reason for its use was to simplify production and eliminate mistakes. It was much easier for the assembly line worker to use a two letter code to choose the correct carb to install, rather than be confused by the seven digit part number. I have started a list, but it is somewhat incomplete, since there are some rare Q-Jets for Pontiac, Buick, etc, that I have not been able to find yet. Rather than list them all here, if anyone wishes to confirm them, PM me and if I have it I will confirm for you if I have it. I have most of the Chevy ones, still working on some of the rare early AIR Stuff.
Jeff Dotterer
Dated Components
Not sure I totally agree with this, or maybe I mis-understand what you wrote? And it was my mistake on the #9207 carb, but say a #29215 carb that was used on all Chevy models.
Obviously the 2-letter stamp will match the buildsheet. I was thinking that after that each model would have it's own 2-letter stamp, as the carb was already identified as Cali, smog, etc ... by the carb #.
So what you're saying is that a 29215 carb for a Chevelle, might/would have more than one 2-letter code designations. It's far more complicated than I thought if that's case.
Thanks, Neal
Thanks, Neal
Neil,
Yes, you did mis-understand what I wrote. Maybe I can clarify it for you. Each carb number does have its own assembly code, and it does not change. It has no determining factor on which model or car line it goes on. It simply identifies that particular carb. Think of it as a factory "shorthand" for that particular carb. I will list all 69 Chevy ones I have for reference, since this post is about 69, and its application.
#7029200=EE 396 325HP AT Chevelle, Camaro
427 335HP AT Full Size
#7029201=ED 396 325HP Man Chevelle, Camaro
427 335HP Man Full Size
#7029202=DH 350 255HP AT Chevelle, Camaro, Nova, Full Size
350 300 HP AT Chevelle, Camaro, Nova, Full Size, Corvette
#7029203=DY 350 255HP Man Chevelle, Camaro, Nova, Full Size
350 300HP Man Chevelle, Camaro, Nova, Full Size, Corvette
#7029204=FF 396 350HP AT Chevelle, Camaro, Nova
427 390HP AT Full Size, Corvette
#7029207=DA 350 350HP Man Corvette
#7029215=EH 396 350HP Man Chevelle, Camaro, Nova
427 390HP Man Full Size, Corvette
As a note, all of these carbs except for the #7029207 are used on Chevelles.There are also other numbers for trucks, and I did not feel the need to get into that here. They are different. Also, that two digit assembly code is repeated in other years, sometimes with something totally different. As an example, a #7041203 (1971 350 270HP Man Trans carb) was a DH code, even though previously was used on a #7029202, (which was automatic). So each code was used in other applications, and does not ID anything other than that particular carb, for that particular year. And if you look in the carb block on a build sheet, it will only list this code. Assembly line workers job was to put the correct code carb on the car per build sheet. I guess we could look it as a way to idiot-proof it, so anybody, even the most uneducated, could do that job and not install the wrong one. This is true of all assembly codes. It cut down on mistakes. Hope I have cleared this up. If not, feel free to ask more questions. I do not know it all, but I can usually help when it comes to Quadrajets.
Jeff Dotterer
Dated Components
1 - 14 of 14 Posts
