Hello Team,
I just installed a 20 gallon stainless gas tank and straps from Ausley’s. The tank looks good but is a bit bigger from the original. I have about 1/4” clearance from the inside frame rails. I don’t like the belly on the straps. I’m most likely going to pull the tank back down and bend the straps to pull them tighter to the tank. I tried using my stock bolts to attach the straps but they were too short since the tank is a bit bigger. I ended up using 5” stainless bolts. On a positive note, my fuel gauge went from pegged full to empty so I know the new fuel sending unit works. Anybody have issues with these stainless Ausley’s tanks? Also has anybody had leak issues with the repro fuel line pinch clamps?
Thanks,
Javier
Thanks,
Javier
