Has anyone ever cut out the Cowl Induction parts of a 70-72 CI hood and grafted them onto a 69 (or even a 68) hood? It would seem to me that a Correctly done FUNCTIONING 69-68 CI hood would be the ultimate. And if the aftermarket vendors made them, I would expect them to be a hot item. It seems like someone such as Goodmark could make a nice one.
The first thing I want to point out is that the '69 CI hood is a fully functional
Cowl Induction Hood (
provided you have a '70's CI Air Cleaner Assembly under it up). The '70's flapper door is pretty much nothing more than "eye candy."
I bought a (
very) used GM '70 CI hood in the hopes of using the '70's pieces on my '69 CI hood. When I compared it to the aftermarket '69 CI hood with the idea that eye candy is cool. I found that the "spear" down the center of the '69 CI hood is a problem as it interferes with where the flapper door opening goes (
perhaps a minor issue if you're a really decent bodyman doing your own work). On the other hand, the underside of the two hoods in the area where the flapper door mounts is a bigger problem. None of the structural sheetmetal lines up, resulting in many hours of bodywork to fab the supports, etc.
Obviously, I agree with your assessment, such a hood would be way cool.
