I have the original in dash tach that was checked out and I was told it does not work. My question is can it be fixed to work with HEI ignition? Also, where can it be fixed? I live in Canada about 1 hour from Detroit Michigan. Are there any shops in Ontario, Canada or near Detroit.
Hey welcome to Team Chevelle!! You can't live too far aaway, let me know the next time you plan on coming to London - or send me an email.
Ron Cook TC Gold Member #1276
1969 300 Deluxe HTSS396 69 300 Deluxe 325HP L35 69memorylane 1971 Malibu 2DR HT
"Supporting all car hobbyists, even those with different cars, is what being a true enthusiast is all about."
Your tach should work w/out any problem with
a HEI Distributor. You need the lead wire from the tach(usually green) to go to the negative side of the coil. On an HEI distributor look for the "tach" plug next to the power wire for the distributor. Hope that
helps.
