1 - 2 of 2 Posts
Hello, I was wondering if anyone could give me some advice for removing the ignition out of a 69 Buick Skylark column without keys. I have removed the steering wheel, lock plate, signal arm and screws that hold the wiring in place but am unsure how to actually remove the lock cylinder itself. The car's ignition is in the lock position and I do not have any keys to move it out of this position. Any advice would be much appreciated. Thanks
I can pull out my Chilton manual that has step by step instructions on how to do this and send it to you. It;s actually fairly simple. The is a small hole in the side of the cylinder that you have to insert a small pick into to depress a lever and the cylinder will pop right out.
1 - 2 of 2 Posts
