hey, i have a 1968 chevelle i was trying to get the trimming off and i dont no how to get it off . the one above the door i think its call roof rail weatherstripping does anyone no how to get that off
-ryan
There in there. Flat head phillips screws. You need to use them or replace with the same kind when you put it back together. Once the screws are out it will still be stuck to the car. You have to gently pry them lose. Next will be your rain gutter trim and you want to save your originals as the repo's aren't good. Sit in the car, get a small block of wood to catch the lower edge and then tap it loose.
