1 - 20 of 40 Posts
I'm buying a 68 SS Chevelle 4 speed with a 454 in it. The 454 is fine but I would like to know if replacing it with a 396 would make any difference in the value of the car because it will not be the original engine either? Also it needs to be painted so should I go with the original color or the one I like the best if that does not affect the value once finished? Last the proper SS stripe on a 68 goes in front of the hood, down the front fenders and continues past the door. My preference is the 2 stripes that go down the hood and on the trunk. Once again will that have a negative effect on the cars value once complete? Thanks for your inputs.
Thank you gearhead SS that seems to be good advise on the engine. What do you think about striping and colors that are not original as to the car's value once complete?
If you are going to keep it, as said above, do what makes you happy. If the car is destined to be resold you want it to appeal to the largest number of people in a cost effective manner. If the original color is unpopular changing it shouldn't matter, as long as the work was done well. Stripes are really subjective, maybe do them in vinyl so they can be removed at a later date.
Steve R
Also, what would a 68 Chevelle SS completed as I have described be worth? In general terms.
The trend seams to try to put the true 138 VIN Super Sports back to the way they looked from the factory appearance. Keep the 454 and dress it as a 68 396, paint it the original color, put disc brakes on it, and factory style wheels. That will max out the value if your plan is to sell it soon down the road after it's done. Are you doing the bodywork and paint yourself?
1968 Chevelle Malibu, upgraded to a 396/TH400 from a 327/PG
Prices for 1968 138 cars are nuts. I've been watching prices for a couple of years now and they're on the rise again. A few weeks back, I posted a car on here for advice. I was thinking 23k, tops. There were some warning signs that were brought to my attention, sobriety kicked in, and my wife and I decided to stay home instead of going to look at it. It was a 138 car, 454, TH400. Needed paint, attention under the hood, exhaust, and other things. Seller was asking 28,900. It's still for sale. I'm assuming that's because of its many faults. My guess, when all is said and done, is you have a car worth between 25-35k. All depending on the finished product, of course. As far as stripes go, I'm not a fan of the stereo stripes on anything besides a '69 Z/28 or a 70-72 Chevelle. But, it's your car so do with it as you wish. Keep in mind, while I'm looking at cars, I pass on anything 1968 with the stereo stripes. Just my personal preference.
Reactions: Steve R
I have a 68 with the racing stripes on the hood and trunk, that's the way I bought it. I think it looks OK, but if I would do it again I would probably go with original 68 SS stripes.
Not too many people know that's not the correct stripes, so I don't worry about it too much. if you like it then put them on.
Back in '88 I did my 68 Chevelle (non-SS) that way. Looking back, I wish I would've went with the original color and the correct stripes. Everyone has stripes on their hoods/trunks. Nice to see something different once in a while.
Thanks to everyone for taking the time to enlighten me. I'll keep the 454, go back to the original color, 68 stripe, install front disk brakes but does anyone have a picture of the correct 68 SS wheels and a good place to find them?
Definitely keep the 454.
I have a 454 in my 68 ragtop. It's dressed up like a period 396 and you'd never know unless you checked the numbers. I've never seen anyone at a local cruise night checking the numbers on my block.
As for the color and stripe, at the end of the day it's your car and you should do what YOU like. If you are fixing it up with the mindset that you are going to one day sell the car, then by all means try to keep it stock looking.
SS cars in '68 came with either corvette style rally wheels or steel wheels and some different hub cap options. I believe 14" diameter by 6" wide was the standard size. Someone will surely chime in if I'm wrong, which is likely. As far as correct goes, if it were my car, I'd make the choices to my taste. You'll be the one driving it and enjoying it, make it what you want.
Discussion Starter · #14 ·
Do you have a picture of the Corvette style rally wheels that should be on the 68 Chevelle SS's? Thanks.
Discussion Starter · #15 ·
OK, here is the latest information. The paint code is R-2 which I'm told means red with a black vinyl top. Two questions, if I don't install a new black vinyl top as it currently does not have one and I'm not a fan will that have a negative effect on the value of the car once complete and what color should the SS stripe be? Thanks again.
IMO, an R2 paint '68 with a black factory stripe would look sweet. I'd slap some cragars on it, give it a little rake and just a couple day 2 items and call it done.
I don't think NOT having a vinyl top will hurt the value. Frankly I've NEVER been a fan of vinyl tops and when I was Chevelle shopping I passed right over any potential car based on seeing a vinyl top.
Since we already know that the numbers matching motor is gone, changing to a hardtop look shouldn't hurt anything because you are already "not original".
Discussion Starter · #18 ·
With that in mind (not all original) does it matter if the rally's are 14 x 6 or is 15 x 7 or wider good? My all time favorites are Cragar SS's so will a nice set of Cragar's be just as good (Value Wise)?
Quality of work and continuity is what drives value.
Steve R
A far as wheels, put on it what you like, Cragars included. Wheels are the easiest things to change, so no matter what wheels are on it, a buyer in the future can change to what the buyer likes, unlike paint or stripes, which are a little more permanent.
1 - 20 of 40 Posts
