I'm just finishing restoring the frame on a 1968 Chevelle. During the restoration, I put on a set of reproduction front disc brakes on the frame. My question is:
The car was a "basket case" when I purchased is a year ago and the frame was missing all of the brake line/hardware. I planned on replacing all of the brake lines anyway; but, what is the best way to run the new brake lines? In the front disc brake kit I bought, it came with a proportioning valve that mounts underneath of the master cylinder.
The car was originally a non-power drum brake car and I have no idea if it had a distribution block that was originally mounted on the frame. When I buy a full brake line kit, do I need a new distribution block that mounts on the frame so all of the rear and front brake lines have a place to meet before the lines go up to the proportioning valve on the master cylinder, or do the front brake lines go from the flexible caliper brake lines all the way up to the new proportioning valve?
I'm not too concerned about originality, but I also don't want a bunch of splices or couplers holding the brake lines together if I need to bypass a distribution block.
Dan
Dan
