1 - 9 of 9 Posts
I'm at the point in my restoration that I need to buy a set of front coil springs. The car is a 1968 Chevelle with a 396 BB, No air. I would rather have the car sit a bit lower in the front than higher. Can anybody recommend a Moog part number?? I fought with the the front coils spring height on my previous car and I dont want to keep taking out the springs to get the right ride height. Thanks in advance...
Dan
http://bbb-carb.com/moog_Coil_Springs.htm
Correct spring non-ac is 5400. W/ AC is 5374. Both of these have longer free heights than the 5390 I just installed on my 69. Mine does have alum heads, intake and radiator. Had to trim 1/2 coil to get the ride height I like. Compressed spring length at ride height should 11" for these cars at factory ride height.
· Banned
THX Bro......I have the front end off now.......... Going all moog, figured while the springs are off, why not replace em too since replacing everything else.....
http://bbb-carb.com/moog_coil_springs.htm
correct spring non-ac is 5400. W/ ac is 5374. Both of these have longer free heights than the 5390 i just installed on my 69. Mine does have alum heads, intake and radiator. Had to trim 1/2 coil to get the ride height i like. Compressed spring length at ride height should 11" for these cars at factory ride height.
note that is not listed as per moog cataloging / they specify in their f2925 coil spring catalog part number 5374 w/o ac and part #5400 w/ac 396 s/s and sport coupe 1968.The site listed is not Moog.
1 - 9 of 9 Posts
