I built an 11:1 compression 396 for a friend for his 4200lb 3/4 ton.
Block and heads were from that 1969 truck, large oval port open chamber and I went with 2.19-1.88 valves.
Ported the heads and roughed the intake runners.
280H comp magnum cam ground on a 108LSA so intake valve actually closes earlier this is a
[email protected] .050 .480" lift sbc cam lobe master but calculate that with a 1.7 rocker arm you get more duration and much more lift.
91 octane 38 total timing. Has ran excellent and seen 7000 rpm a few times.
Been running strong for over 10 years.
No sharp edges in combustion space and no issues with oil in combustion space either as that will destroy one quickly.
210 psi cranking pressure
My sbc engines with 58cc or smaller I can get by with a lot more than 11:1 and 245 psi cranking pressure on 91 octane.
These are iron heads.
I will say this I ran a milled to 54cc 186 head (double hump) on a 350" and a 64cc 041 double hump both same size valves and same port job.
I had to remove 4 degrees initial timing and delay total timing by almost 400 rpm with the larger chamber head.
More to this question of yours than just what compression or what cam.
Press fit or floating .I would not care but they need to be good forged pistons.
Good stock rods have never let me down either.
But maybe i am not making enough grunt to hurt them.
