I have a 67 SS convertible. It has an EF coded numbers matching pad. The intake is the Q-jet spread bore style and I got it with a closed original air cleaner with a weathered but ledgable 350 hp decal. The carb is a stick carb and the distrib is a 1111169. I have seen original 350 hp cars with holleys on them as well but they all seem to have open air cleaners. My intake casting date is matching as far as being cast as the same week as the block. The question is were there two styles of 350 hp engines and can you spot them by if they have an open or closed element? Second question: Did non A.I.R. cars use exhaust manifolds with square plugs in port tubes? I have found so many originals this way and have to think they are correct.
Look forward to the input on these questions. Regards, Jim Keegan
