thge car is just about done and as I look at it the rear end sits about two inches lower than the front. I do not want air shocks, any ideas to raise the back end about two inches?
X2 :yes:Do you have the correct rear and front springs? It took my car a couple drives before it settled out and sit level
How is that going to raise the rear of the car?You can always drill a new set of lower shock mount holes a couple of inches above the ones that are there.
Good catch! I did it, but I'm still running air shocks.How is that going to raise the rear of the car?
Shocks do not support the weight of the car, springs do.
i ordered a pair of extra high springs from j c whitney i put them on my 65 chevelle and on my 67 elcamino raised them between 2 and 3 inches ck the j c whitney cat.thge car is just about done and as I look at it the rear end sits about two inches lower than the front. I do not want air shocks, any ideas to raise the back end about two inches?
