Purchased this a while ago and was wondering what it might bring in today's market?
Here are a few things that I do know and I am sure the list is longer related to items that I do not know
Originally purchased at Sawicki a Chevy Dealer in Rochelle Illinois.
I am the 3rd owner of the car.
Believed original mileage shown on odometer from previous titles.
Original black bucket seat interior with original carpet still in car.
Blinker tach still in car but does not work
4-speed car
I do have the 4-speed console; just not in the car.
There was Sun tach attached to the column that was removed as it did not work.
Correct narrow 12 bolt rear stamped as Eaton posi with 3:31 from factory. Now has 1969 3:73 posi gears with old-school ladder bars and air shocks.
Original radio gone with cheap replacement.
Extra three gauge set installed at some point under dash just ahead of shifter.
Was painted black with lots of runs and sags sometime in the early 80s as it should be marina blue. Doors close excellent with no sag. Front clip looks to be original replacement GM early in its life.
Floors and trunk pan are in very good shape.
Engine is 4-bolt main from 1970 with CE stamp with oval port heads. I am guessing a replacement at some point massaged by the speed shop (Speed shop sticker in both vent windows of which I believe did some work on the car at some point).
It also has headers with short mufflers bolted to them and that is it.
Cragars are old school non-unilug and cleaned up well.
I replaced the points, changed oil in engine (Brad Penn) and rear end and also purchased a new carb. Siphoned out all gas and pumped new gas through lines before reconnecting to new carb. Turned it over by hand several times then started car, set the dwell, and set the timing. Car starts and runs like a scalded cat and will squeal the big meats at nearly any point.
Thinking of restoring during retirement but wanted to understand approximate value.
Let me know what other questions you may have to better estimate value.
As a side note, I was only allowed to upload 10 pics but I do have many more.
Thanks,
Vic
4-speed car
Thanks,
Vic
