I'm looking for the lower bolt and J nut that goes on the bottom of the fender? That attaches it to the body.
Any ideas?
I got mine from salvage yard that only has GM vehicles from 1950-1980's. A place where you find the vehicle and remove the part yourself. Think I paid $4.00.
A bolt that goes vertically up through the fender clamping it to the body? Most are 5/16" body bolts, and the clip nuts, as well as the bolts are as close as the hardware store. The clip nuts aren't the same as GM, but time marches on. A few are bigger and a bit more complicated but more info may be needed.
For those of us w/ loose morals, a troll through the local pick a part will lead to lots of body bolts lying on the ground begging to spend time in your pocket...
