1 - 10 of 10 Posts
66 Chevelle SS396 & 66 Chevelle 327 Convertible.
Looking to install an original KK tack in my 66. Car did not come with Tack from factory. Does anyone have the dimensions of the reinforcement installed on the backside of the dash. Or do you guys just make one for the mounting hole and one for the the wires using the dimensions in U16-A2, 11/16" and 0.58" out of some say 3/32 stock?
Also Is there a simple way to wire the tack or do you have to use that Tack Harness? My tack has had the connectors cut off the wires exiting the tack; but I still have about 6" of the Gray, Brown, and Black wires. I guess it would be nicer to add the 3 connectors. Thanks,
Reactions: davewho1 and Greg P
i could take a pic of the backside of the dash as mine is off right now.if i don't have any calls tomorrow i will be out sanding and can take a pic.
Super Moderator
1966 Chevelle SS396
Here is a drawing I used to make one. I used a piece of 19 gauge from an old dash top. The other pic is of an original and does not have a cut for the wire like the repro.
As I recall, you made several. ;) :thumbsup:
1 - 10 of 10 Posts
