I just received my reproduction tach and want to confirm the power for the tach needs to come from a switched source, correct? I'm replacing the clock, so I can't use that as a power source right, because it's always on.
Also, is the rev limit analog markings are set to: Yellow= 4900rpms Red=5000rpms. Is this the right range for the 327? Not even sure if I can move them if they aren't.
