Well, I needed a support for my 65, and couldnt find one, and the I came upon a 64 support. It was basically the same, but the top bolt holes are different. I ended up not really caring and drilled new holes for my bolts. It works and looks great. So if you are doing a restoration and want things correct and proper, get the correct one. If you are not worried too much about a little modification, then it will be fine.
T-Bone
Here's the deal on 64 and 65 rad supports
The 64 rad support when installed uses NO
rad support bushings just the flat washer
wuth the nut/bolt. where as the 65 uses the rubber bushing and washers for mounting.
so to answere you Question. YES you can use
a 64 on a 65 BUT DO NOT enlarge the holes
and install the bushings ( you will have sheet metal line up nightmares! ) YOu can use a 65 rad support on a 64 but USE the bushings. OK ?
Have fun
Wayne
ACES 1556
TCG 186
