Does anybody know where I get a stock radio on the cheap. It doesn't have to work, I just want to fill the hole. Or better yet what is your advice on what to do with the radio hole?
Thanks,
Jon
Thanks,
Jon
I did the same thing to just fill up the hole. Dont remember seeing a hookup for a light bulb although mine did not have a harness. Does the light snap in like the gauges or is it internal?I bought a non working one off of ebay for 50 dollars. If you just want to fill in the hole, make sure you do hook up the radio light bulb. It looks good when your whole dash is lite up at night.
The light is internal. You need to get power to the radio for the lights to work.I did the same thing to just fill up the hole. Dont remember seeing a hookup for a light bulb although mine did not have a harness. Does the light snap in like the gauges or is it internal?
Yes,Thanks, I do have the power wire since my aftermarked stereo uses it. What turns the light on and off since the power wire is always ignition hot. Is it the radio knob?
