I was just curious if anyones running the better 18 degree heads and what mods were necessary (lifters, rockers, block mods)and if you felt it was worth the hassels over the comon 23 degree heads, Ive worked on several of them over the years and know most of the info, but I was recently told that its now far easier too do as some design mods have been made to ease the swap process
http://brodix.com/heads/-18c.html
http://www.trickflow.com/product/chevycylinderheads/18degree_raceheads/pr_18degree_race.asp
http://www.dartheads.com/manager/uploads/Tech - 18 deg SBC.pdf
before you start posting.....yeah, IM well aware of the offset roller lifters and shaft rocker assemblies , special pistons, intake manifolds and differant pushrods
ETC. the older system used,
and YES IM aware of these heads BELOW that use standard roller lifters and standard roller rockers, standard headers,and only require the newer intake manifold and heads and pistons, and differant pushrods
http://brodix.com/heads/-18x.html
but are they worth the effort VS the 227cc AFR 23 heads below....notice the flow curves very similar between the heads
http://www.airflowresearch.com/227sbc_rh.php
now, I know I didn,t tell you the displacement, compression ratio or application, Im just looking for the basic responce from anyone whose run BOTH heads and its a given that were looking at a 100% race application with the 400 plus displacement and higher 13:1 plus cpr that will involve to get the most from the heads potential
