I like the look of the cars using 18" in the front and 20" in the rear American Racing torq thrust wheels. My question is what offset is needed for this setup? I assume the fronts are 18x8 with a 0 offset and the rears are 20x8.5. But what offset for 20" +0, +18, +20, +32? Also what width tires will fit? 245 in front and 275 in rear? Thanks
for 1971 chevelle, lowered 2"
Not sure of the offsets but you can easily run a 20x10 rear with a 5.5 back spacing, the fronts I believe should be a 4.5 bs, 275 will fit in the rears no problem but I would go with a 285 if you went with a 10" rear. Be careful choosing tire sizes for the wheels so you do not end up with a front tire that has a higher sidewall height then the rear( looks ridiculous IMO)
Which wheels are you looking at?
