I Have a 69 Chevelle with a 10 bolt one-wheel peel. I also have a 12 bolt posi from a 64 GTO. Anybody have any advice on what to look for for a potential swap?
Swapped a rear end only once. Was relativly easy,an 85 Fleetwood, into an 86 Fleetwood Limo. Ya think I'm looking at a can of worms, or somewhat easy.?
Pretty easy, just heavy and dirty.
Support the car on jack stands. Remove the wheels. Remove the drive shaft. Disconnect brake hose and e-brake cables. Support rear end on a floor jack. Remove lower shock bolts. Lover rear end and remove springs. Remove upper and lower control arm bolts.
