1 - 9 of 9 Posts
I bought an old 12 bolt Posi rear end that was previously installed in 55 chevy with leaf springs so they removed the brackets for shocks, springs and lower control arms.
Any ideas where to purchase these or possibly remove from and old 10 bolt rea end
there's was the same set up advertised on the local Craigslist, I was texting the seller tryong to convince him to sell me just the rearend. local differential shop has a jig to weld the brackets back on, that's why i was interested. jim
Pick up a donor 10 bolt, same parts and they’re cheap. -----------------------------------------------------------
THAT IS EXACTLY CORRECT!!!!
The 12bolt in our 70 came from a salvaged 71 El Camino which had the lower trailing arms all bent up. I ran across a junk 10bolt and VERY CAREFULLY cut off the brackets on both housings and welded the brackets from the 10bolt onto the 12bolt. Been like that for about 12yrs.
i looked at craigslist, did not see any thing, will have to keep looking or look for a 10 bolt donor rear end
sounds like a good idea, try to find a donor 10 bolt
1 - 9 of 9 Posts
