1 - 11 of 11 Posts
· Super Moderator
Rudy,
I am pretty sure someone makes replacement billet caps but you will need to get a good machine shop to align bore them to match the housing. Might be easier (and cheaper) to just get another housing or buy a new one from Moser etc.
I like the Mark Williams caps. Have them fit at your local engine machine shop. They can use a Main/ rod cap cutter to fit the caps. Take lots of measurements. Tom
Truck 12 bolt caps will fit, but they must be fitted to the housing. You can also use the after market caps and have them fitted. The bearing bore MUST be round and the correct size or you will have problems.
I have it at a shop now and there telling me the housing is junk if I dont have original caps so your telling me its not? Is it worth finding truck caps from a junk yard or buying new ones and having them fitted? This housing is already powdercoated and ready except for the caps.
I am will to take your housing in on trade for a rear built by me and probably allready in stock. What ratio do you want? Tom
1 - 11 of 11 Posts
