Ok here goes, i have a 461 with 11.1 comp. Square port heads(fully ported and pol.) Comp cams 638int 631exh #11-605-5. (solid). weiand stealth intake with 800dp, GER 4000 stall T-400, 410 gears, [email protected] slicks 275-60-15. In a 1968 SS396 chevelle with a/c, p/s,Bench seat int, I know this car is a bit on the heavy side but this car should be running LOW 12s or high 11s right??. On the desktop dyno it showed over 600hp. Also in my bros Chevelle it ran 12:11 @116. The only diff is no ps,ac, and he has 4-speed!!. Please help me.....is my converter slipping too much?? CHRIS
