Excellent. Very useful information. Saves a lot of grief after the fact.
I now have two engines with the same problem, Now getting them to pay for oil pan gasket, Oil and oil filer and labor should be fun. Lucky the Dist. gear looks good.Excellent. Very useful information. Saves a lot of grief after the fact.
I have always used the yellow spring which will put you at around 62 pounds, Yes shorten the valve so the whole bypass hole is exposed.hi
WOW
100 psi on the dyno sheet on an engine that sees 6000rpm so,, 60--70psi would be ok and idle 20psi +.
About to assemble
Just checked my 10552st pink spring
Piston travels freely in bore
##### Fully retracted piston covers 20--30% relief hole
Details
It looks like 3/16 inch needs machining from bottom of relief piston so it opens hole up a bit more .
## Does shortening piston actually cure the problem when running .0025 mains clearance
or is it more about hole placement ???
Are people having success doing this mod . Oh yea please state what spring your using .
EG pump comes with 3 springs pink installed ....
When the bypass hole is restricted it really does not matter what oil you use and what the temp is.hi
was the engine hot ?? and the spec of oil 10w/40 etc or different ??
idle pressure at what rpm ??
62psi at what rpm ??
I think there is more going on with the cover, I have a friend with a 12552ST and a 10555T pumps are have about 65 PSI hot oil. At some point Mellings made a cover change and I believe the problem starts there.So is the only real solution to shorten the piston? Great info for anyone in the process. I’m surprised more engine builders aren't getting sick of all the time used up redoing pan gaskets.
hi
1/ Concern about over pressurizing
2/ potential issue is piston is closing pressure relief hole by 20-30%
Specification of piston [main circular body ] protrusion into relief hole is .030 inch
Investigate [ measurement from Melling ]
1/ relief piston total length is 1.625 inches
2/ relief spring plug total length .500 inch
spring plug threaded section = .length 370---..380 inch
****If the dimensions are correct the housing has the hole drilled in the wrong position ? TBA.
I don't know if the bypass hole is in the wrong spot or it would have showed up when I primed the engine on the stand same as all the 10552 pumps it was 58 PSI on the drill with the yellow spring. at low idle it on the dyno it was appox. 35 to 38 pound wish has always been normal.hi
hi
I suspect core shift in the casting . I have now checked all my pump factory specs and the location of the hole is the only thing left that can be incorrect . What concerns me is
1 / springs have a very complex design ,ie will shaving the piston work ?
2/ will coil bind [once machined ] occur and not let the piston to fully retract anyway ??
