1 - 10 of 10 Posts
The factory delco radios require 10 ohm speakers. Is it possible to use 8 or 4 ohm speakers without causing damage to the radio?
Originally posted by John_Muha:
Eight ohm speakers will do the job.
Four will rapidly burn out the output transistor in the radio (too little impedance = too much current = too much heat).
Reid
Thanks guys...don't want to burn out a good AM/FM radio...they're worth too much money these days! by the way, what happened to Radio Joe and his website?
Originally posted by Joey B:
What about a 6ohm speaker?
Circuit is designed for 10 ohms. 6 is too low. You can tie (2) 4 ohm speakers together and make 8 ohms. That would be closer.
1 - 10 of 10 Posts
