I have a chance to pick up a DART aluminum block with a 10.4 tall deck. I plan on putting an 8-71 blower on it. Will I run into fit issues with the regular tall deck manifold? I am running Trick Flow Power Port heads. Thanks
In Memoriam
not up on 10.4. 10.2 is the usual number for a tall block. And, no the 10.2 manifold wouldn't work on that block without spacers which are usually made for 10.2 blocks.
In general, usually smart to avoid oddball combinations of expensive parts unless you've got deep pockets down to your socks and a lot of patience.
In Memoriam
Looks like I'm still in the stone age. several vendors offering 10.4 aluminum block.
Why do you think you need that tall block? are you running some humongus crank deal?
