this should be an easy question with the multitude of chevelle owners here, does any one know of a place that makes a very good quality/fitting 1 piece molded carpet for a 70 chevelle? i can only seem to find 2 piece.
It may be a bit tricky to find a one piece because the carpet itself is only so wide (like 60") so you have to have a seam somewhere. If you can't have the visible seam, have a home carpet installer give you a thermal glued seam that should be almost invisible.
