Refreshing my LS7 454 , keeping mostly stock bottom end except I milled down the solid domes to 10.2 SCR with h Brodix RR 270 ovals 110cc head, should use Air Gap RPM intake and 850 DP.
But I may repurpose the heads and intake for another build in a few years and may install a set of ported 2.19, 1.88 781s and Qjet RPM intake after.
Cam is small but I like oldschool cams, its a UD 402A3 Solid lifter with 160 dur @.200 so its a street friendly cam but still some intensity to it.
To take advantage of the good flowing 270 Brodix RR ovals at higher lift, I plan on running 1.8 HS rockers VS 1.7.
Ive done that numerous times on race engines without adverse effects ( actually reduced wear at the lifter) but what about street only use? Anyone with real 1.8 rockers experience on the street with SFT cams?
Please dont tell me about wiping lobes with SFTs
Peter
Peter
