Ok, before I start, this was my very first time running on the 1/4 and had a GREAT time! I've ran on the 1/8th a few times, and have my best et in my sig. Ok, before I show my results, I gotta admit to 3 mistakes that I did. 1., I never checked my timing. I was soo caught up in trying to finish primering my car, and getting my motor prepped to pass tech inspection that my timing totally slipped my mind. 2., After my first pass, I bumped my timing just a bit by eye balling it, and again, didn't check to see what my timing was. 3., on all of my 3 passes, I never looked at my tach to shift (well, I did once on my last pass...I held 2nd gear longer then I did fist gear), I was shifting by ear. Ok, now my results...
Pass 1.
R/T .... .085
60' .... 2.055
330 .... 5.620
1/8 .... 8.589
MPH ... 82.27
1000 .. 11.175
1/4 .... 13.366
MPH ... 102.70
One thing that I noticed was that on all three passes, I wasn't able to hook right (when I launched, all I felt was the car fish tailing from left to right as the car was moving forward). I couldn't even heat up the slicks right. When heating up the tires, I had to keep the rpms below 4500rpms or else the rear would start to swing out. I couldn't even get much smoke to come outta the slicks. On this first pass, I stalled the motor up to 1500rpms, and on the 3rd yellow I floored it.
Pass 2.
R/T ... .216
60' .... 2.136
330' ... 5.694
1/8 .... 8.739
MPH ... 80.44
1000 .. 11.362
1/4 .... 13.573
MPH ... 102.06
On this pass I decided to experiment on my launch, and instead of stalling the motor up, I launched off of idle, which caused the motor ended up bog off the line. Again, I shifted by ear, but this time, when shifting from 1st to 2nd, I missed shifted and shifted into drive. Before I make this 2nd pass, this is when I bumped my timing by eye balling it....I moved it no more then an 1/8th of an inch or so advanced.
Pass 3.
R/T ... .023
60' .... 2.003
330 ... 5.548
1/8 .... 8.526
MPH ... 82.21
1000 .. 11.122
1/4 .... 13.33.
MPH ... 101.81
On this pass, I went back to stalling the motor to 1500rpms, and lauched on the 3rd yellow. Again, when making the shift from 1st to 2nd, I shifted by ear, but this time, I ended up shifting into drive again and felt it, so I shifted it back into 2nd before the tranny shifted into drive. I took a quick glance at my tach, and noticed that I had shifted from 1st into second at roughly 4800-5000rpms, so knowing this, I held 2nd longer and shifted at roughly 5800rpms.
When I say roughly, it's hard to tell exactly what rpm I'm really at because the tach isn't accurate....yeah, I know, BUY A NEW TACH!!! LoL
I know it's off because I've got a 6000rpm pill in my 6AL, and when I rev the motor to 6000, the rev limiter starts kicking in between 5600-5800rpms :sad:
Pass 1.
R/T .... .085
60' .... 2.055
330 .... 5.620
1/8 .... 8.589
MPH ... 82.27
1000 .. 11.175
1/4 .... 13.366
MPH ... 102.70
Pass 2.
R/T ... .216
60' .... 2.136
330' ... 5.694
1/8 .... 8.739
MPH ... 80.44
1000 .. 11.362
1/4 .... 13.573
MPH ... 102.06
Pass 3.
R/T ... .023
60' .... 2.003
330 ... 5.548
1/8 .... 8.526
MPH ... 82.21
1000 .. 11.122
1/4 .... 13.33.
MPH ... 101.81
