Chevelle Tech - View Single Post - Sniper Return line
post #2 of (permalink) Old Jul 10th, 17, 9:30 AM
73Eldo
Tj
Re: Sniper Return line
By 78 the vent would have been part of the sending unit. You don't want to use it for a return because it runs into a small baffle at the very top of the sending unit. The return runs closer to the bottom so you are not spraying fuel.
I should go out and hook a pressure gauge on the return of mine which is 5/16 back to the tank then into the original 1/4 sender line. The number I remember is below 5 psi is good.
73Eldo is offline
