Chevelle Tech - View Single Post - 1972 Chevelle SS 454 convert limited slip
post #7 of (permalink) Old Jun 21st, 17, 10:31 AM
big gear head
Freddie
Re: 1972 Chevelle SS 454 convert limited slip
I don't recommend using 33 spline axles with c clips. If you upgrade to 33 spline axles you need to install new housing ends with press on 9 inch Ford axle bearings, or at least use c clip eliminators. 33 spline axles are almost the same size as the c clips, so there is a chance that you could loose an axle. Moser doesn't make 33 spline axles for the 12 bolt with c clip buttons. For most street cars the 30 spline axles are plenty strong.
You do need to check the axles for wear where the bearigns run on them. If they are worn or pitted then they need to be replaced.
big gear head is offline
