Chevelle Tech - View Single Post - Gasket between Air cleaner and carburettor?
post #11 of (permalink) Old Jun 11th, 17, 3:55 AM Thread Starter
FarmerJoe
Patrick
Re: Gasket between Air cleaner and carburettor?
Thanks for the tip Randy!
IŽll order a few more parts this evening, and that gasket will be part of it :-)
I hope they are not too thick. The air box is already rubbing on the hood insulation. That Airgap RPM intake is building a bit high for the 64 El Camino hood it seems, so every fraction of an inch I can save is good. Maybe thatŽs the reason the previous owner did not put a gasket in. IŽll see, it does not cost a fortune ;-)
64 El Camino, 454/TH350/3.36-one-tire-will-die-first-style-rear
FarmerJoe is offline
