Umi 4062 - Chevelle Tech
UMI Performance
  • 1 Post By Jasons 69 Chevelle
post #1 of 5 (permalink) Old Jun 13th, 19, 12:23 AM Thread Starter
Jason
Umi 4062
Looking at these front lower control arms. I couldn’t find instructions on UMI web site. Does the 2 bolt mount on bottom of the shock just get pressed out and installed on the lca mounts?
Jasons 69 Chevelle is offline
post #2 of 5 (permalink) Old Jun 13th, 19, 9:57 AM
Allen
Re: Umi 4062
Originally Posted by Jasons 69 Chevelle View Post
Looking at these front lower control arms. I couldnít find instructions on UMI web site. Does the 2 bolt mount on bottom of the shock just get pressed out and installed on the lca mounts?
I Just read the description on UMI's site. The referenced arms are for use with 1/2" rod end coilovers, if you are planning on using stock style mounting shocks, look at one of their arms designed for that.
I wish my arms were set up like the 4062 with removable lower coilover shock mounts as it would make playing with the rate of coilover springs (changing springs on the coilover) very easy.
Blown1932 is offline
post #3 of 5 (permalink) Old Jun 13th, 19, 11:19 AM Thread Starter
Jason
Is the T-Bar mount removable from the qa1 coil overs. I have aftermarket suspension now. I plan on increasing the spring rate and would like to go with this design. I seen the 1/2 rod end shocks are required. But don’t see any part numbers Or shocks on their site with 1/2 rod ends.
post #4 of 5 (permalink) Old Jun 13th, 19, 11:26 AM Thread Starter
Jason
Ok found a qa1 conversation kit part number Com8t-102pk. It switches the t-bar style to 1/2 rod end shocks.
Blown1932 likes this.
post #5 of 5 (permalink) Old Jun 13th, 19, 4:46 PM
Eddie
Re: Umi 4062
Is the T-Bar mount removable from the qa1 coil overs. I have aftermarket suspension now. I plan on increasing the spring rate and would like to go with this design. I seen the 1/2 rod end shocks are required. But donít see any part numbers Or shocks on their site with 1/2 rod ends.
T bar mount is removable from QA1 coilovers.
On my Cutlass I have QA1 Control Arms. Lower CA has a coilover mount that bolts in, which requires T-bar to be removed.
It's a really great design since you can convert it back to stock style shock/spring just by removing the mount.
Name:	Messages Image(1868258716).png
ID:	595626   Click image for larger version
Eddie K is online now
