Chevelle Tech - View Single Post - 1964 4 door Malibu - LQ4/T56 build
post #12 of (permalink) Old Mar 1st, 17, 11:36 AM Thread Starter
Hotwire
Re: 1964 4 door Malibu - LQ4/T56 build
dat ass! Driver's license plate light needs a new receptacle. The spring that pushes the pin into the bulb center conductor is rusted out. I love the lenses though, they're little ufo shaped, thick, glass domes. Little rubbing compound had them looking brand new.
mangled lock with 1/8" drill to pop it out and get new ignition lock installed, gone in 60 minutes.
Not looking forward to figuring out what I got, what I need, cleaning, straightening, installing, etc.
Test fit the SS rim on the rear. Initial thought, 1 - 1.5" spacer may work. Might require BFH assistance, but I may actually be able to run them. Might be necessary to knock down the tire size to 255, really don't want to go that route though.
these studs kill me. that's the length vs a blue butt connector. Tried installing the rest of the new lug nuts I purchased but the threads are so mangled half wouldn't even start. I just put the old ones back on for now, they dragged so bad going on.
Hotwire is online now
