Chevelle Tech - View Single Post - 1964 4 door Malibu - LQ4/T56 build
post #5 of (permalink) Old Feb 28th, 17, 11:10 PM Thread Starter
Hotwire
Re: 1964 4 door Malibu - LQ4/T56 build
Driver's seat shot
Need to find the mfg of these synthetic hangers, they're crap!
Car already has upgraded front disc brake setup with dual master.
Drivers side "slotted" rotor, one broken stud, one lug finger tight, 2 different size nuts..
On top of the lug nut fun, check out the bearing action on this bad boy! Pass side shows just as much play. I'm extremely glad I didn't try to take this down the road.
https://drive.google.com/file/d/0B8k...ew?usp=sharing
Passenger
I'm fortunate enough to have found a car that was meticulously maintained. There's a grease zerk in there I'm assuming.
Wondered why it had a high idle, one spring wrapped around the engine hook, rusted in half.. twice..
This one shows a couple.. wires going into the firewall through the ungrommeted hole is straight off the battery. It's normal to loop plug wires around your master, right? Check out the shock bushing and stack of shims, and you can just make out the o2 sensor in the bottom of the log (in between 3 & 5 plug wires).
Hotwire is online now
