Chevelle Tech - View Single Post - I boogered out axle seal on Moser
post #8 of (permalink) Old Sep 15th, 16, 10:12 PM
70CHEVELLE396
Re: I boogered out axle seal on Moser
Originally Posted by 70CHEVELLE396 View Post
National seal number 473229
I used my seal puller to remove after I messed up the first try. I bought a seal driver set from Harbor Frieght.
I just want to update this post for future reference. I don't know if the op used this part number seal or not. I got this number after contacting Moser back in 2014. After using this, my axle seal started leaking in 2016. I contacted Moser again, and this time received different info. I was told this time to use a CR15142 seal. Also to watch for a seal that is too thick, as it could contact the bearing press ring, and cause a failure. I was able to buy this from Napa, and according to Moser, that's where they get them too.
70CHEVELLE396 is offline
