Chevelle Tech - View Single Post - 87 buick grand national
post #28 of (permalink) Old Jun 4th, 16, 4:31 PM
LIVE4RDO
Re: 87 buick grand national
Originally Posted by novaderrik View Post
the only thing i hate about the interior of my T Type is the lack of any real gauges and the way the steering column points ever so slightly towards the left. every G body is like that.. it's subtle, and if you never noticed it before, you will now, and it will bug you every time you drive it...
i plan on upgrading the gauges with a cluster out of a 90's LeSabre some day. this gets you a 120mph speedo and tach along with water temp, oil pressure, and fuel level gauges. you can even put a real boost gauge in it that looks factory, and it takes only a little bit of modification to the bezel and making a VSS for the electronic speedo out of any 80's GM speedometer..
Or you can go this route:
1987 Regal Turbo T, bench seat, column shifter, manual windows, original 213k miles.
1968 Chevelle 300 Deluxe, 2-door sport coupe, V8 - one of 6803 produced, purchased all original with 307 and PG. Transformation completed: 454, 700R4, 12 bolt with 3:73s.
2018 Toyota Tundra, 5.7L - DD
2018 Infiniti QX60 - wife's ride, Florida cruiser
LIVE4RDO is offline
