Sniper throttle linkage extension (homemade w/pics) - Page 2 - Chevelle Tech
 12Likes
post #16 of 26 (permalink) Old May 18th, 18, 6:50 AM Thread Starter
Re: Sniper throttle linkage extension (homemade w/pics)
Does the TPS reach 100% if you manually open the throttle blades, right at the throttle body?
You may have a situation like I had on my present car, which was the steel rod that the gas pedal attaches to, and that pivots on the floorboard, was slightly bent, and no matter what, was not allowing the full pedal travel....basically it was "bottoming out" on the carpet, before the throttle blade was fully open....worth a look.
Also, one of my buddy's simply had the wrong cable...it worked fine on his Holley carb, but didn't have enough pull on the EFI throttle body. I ordered him a new cable, from Rock Auto, and it had 2 attachment points for the gas pedal end of the cable.
2000 Pontiac Trans Am WS6
6.0 LQ4, 4L80e, 9", Turbocharged
rel3rd is offline
post #17 of 26 (permalink) Old May 19th, 18, 12:54 PM
I get to 96% when it is hooked to the standard hole. It also feels like it is fully extended. The butterflies are straight up and down.
I can check the throttle cable. This is in a 78 Camaro and it is a stock Throttle cable for a 350.
It looks to me that with that slight tip backwards of the extension I am losing some of the reach. The TPS comes to 80% and I am not getting the throttle blades fully open. That second link allows me to adjust the cable if there is one available that fits the sniper. Otherwise I guess I need a different throttle cable.
8Pack is offline
post #18 of 26 (permalink) Old May 19th, 18, 1:48 PM
Tj
The further from the pivot point you go the more overall travel you need. There may not be enough travel available in the original cable and pedal setup. Try disconnecting the cable from the carb and measure the travel available and then compare that to how much travel you need in the various holes.
I suspect one reason us GM people have issues is the Qudrajet. The primaries were so small on those it took a lot of movement to get a response so they essentially used the 'small hole' and the travel was based on that. Going to the Holley style there is just too much response for the GM Q jet geometry so we move farther out which fixes the geometry but then gives us a travel issue. I wonder if there would be the same issues on a car that came with a 1 or 2bbl carb or if maybe those used a more typical geometry?
73Eldo is offline
post #19 of 26 (permalink) Old May 21st, 18, 2:34 PM
Thanks, good info.
I solved the travel problem on my Avenger by using the adjustable bracket which let me move the throttle cable to get more or take up the slack. I think if I could find one that fit the Sniper that would solve the problem but I still need to check the whole linkage to make sure nothing is bent.
If anyone knows if there is a bracket where the cable can be adjusted please share!!
Rel3rd, was the cable you bought for a Chevelle or a generic GM cable. I have a 78 Camaro that originally had a Quadrajet but the pics of the Chevelle cable look very similar if not the same, but the length may be different....
8Pack is offline
post #20 of 26 (permalink) Old Jul 9th, 18, 1:42 AM
Hi Guys, thanks for the information and pictures I have been trying for the last couple of months to find out what the cause was for my hard throttle and couldn't fine anything on Aussie forums about the problem that's now fixed and the car drives like a manual car should, I have included some pictures of what I did as I have a drop base filter and also wanted to keep my exiting aluminum cable brackets.
Regards
David
ID:	569724   Click image for larger version
ID:	569726   Click image for larger version
ID:	569728   Click image for larger version
LKN BCK likes this.
Monaro1969 is offline
post #21 of 26 (permalink) Old Jul 12th, 18, 9:02 PM
What brand and model number is that throttle bracket. I am trying to find one that will fit the sniper and that looks like it is it....
8Pack is offline
post #22 of 26 (permalink) Old Jul 12th, 18, 11:30 PM
I used this with my Sniper, https://www.summitracing.com/parts/fst-304147
-Dave
70CHEVELLE396 likes this.
'70 Chevelle ZZ383/700r4/3.73, [email protected] -- MS3X efi / Hotchkis A-arms & Springs / B-body 12" brakes / 1.25" F-body swaybar / UMI rears & swaybar / JGC PwrStrUpg
ChevelleFan70 is offline
post #23 of 26 (permalink) Old Jul 25th, 18, 2:55 PM
Justin
I’d like to add to this thread, I had this same exact issue with my Sniper EFI, the throttle was super sticky, very unsafe. I made that little bracket just that you guys said. Bam the throttle is cured and runs like it should!! Very good thread!!
70CHEVELLE396, rel3rd and Nobees like this.
JF74chevelle is offline
post #24 of 26 (permalink) Old Sep 14th, 18, 9:50 AM
Rocky
-Dave
Thanks Dave! So just the kit alone was all that's needed? Fixed the pedal stiffness and still provides 100% WOT?
faded67 is offline
post #25 of 26 (permalink) Old Sep 14th, 18, 9:59 AM
Provides 100% WOT, but does not fix throttle stiffness. I haven't gotten around to finishing my little throttle linkage extension outlined in the first post of this thread.
-Dave
rel3rd likes this.
post #26 of 26 (permalink) Old Sep 14th, 18, 10:04 AM
Rocky
-Dave
Roger that. Thank you.
faded67 is offline
This Thread is more than 671 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
