Holly Sniper EFI..how to do it right - Chevelle Tech
 7Likes
  • 2 Post By MarkP
  • 1 Post By Jebchevelle
  • 1 Post By GoFast Beaumont
  • 2 Post By StevenS
  • 1 Post By andrewb70
post #1 of 15 (permalink) Old Apr 6th, 20, 7:24 PM Thread Starter
Pat
It seems the Sniper is getting some of the best reviews as far as efi setups. What is the proper way to go to do it right and cut no corners on the install?
I am very seriously thinking about this project for fall/ winter but would like to go ahead and start part gathering in the near future..
Pats70ss is offline
post #2 of 15 (permalink) Old Apr 6th, 20, 8:59 PM
This is Very vague question.
My advice, use the coil driver for simple ignition install.
Use the on board timing system not a divorced one
Hookup every function you possibly can
Use and program all functions possible including there safety’s
Make sure all connections are correct.
I personally prefer a in-tank fuel pump setup, but many have been successful with external frame mounts up to 550hp.
Big advocate of Holley sniper systems, my super sniper has worked flawlessly!
1968 Beaumont
540 BBC + 15psi Boost via Single Garrett GTX
Stock looking, and fairly stock sounding
HP and ET not determined yet!
Boosted Beaumont Build:
GoFast Beaumont is offline
post #3 of 15 (permalink) Old Apr 6th, 20, 9:11 PM Thread Starter
Pat
The gas tank was one of my main areas i was curious about. Is it better to buy a new tank set up for efi or mount externally.
I see vids of how to do it on a budget
Not that i have money to burn but I do it I will want to do it right
Pats70ss is offline
post #4 of 15 (permalink) Old Apr 6th, 20, 11:52 PM
Mark
Re: Holly Sniper EFI..how to do it right
Tanks Inc tank, or similar, is the way to go. It is very quiet. Make sure that you use a large feed wire sized for the load. Solder as many connections as you can, and add a bunch of grounds. Holley is very adamant about grounds. Take your time, and read the manual several times. Also, Holley has several general instruction video's.
It isn't terrible to install, so don't worry and have fun.
ChevelleFan70 and Pats70ss like this.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #5 of 15 (permalink) Old Apr 7th, 20, 12:15 AM
wire routing is one thing too holley tells you cross signals can and do happen. so route your wires accordingly.
Pats70ss likes this.
78 Malibu, 402, th350, holley sniper EFI, 9" 3:70, 27X10.5-15 hoosiers quick time Dot pro.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
04 scion XB daily driver.
Jebchevelle is offline
post #6 of 15 (permalink) Old Apr 7th, 20, 12:19 AM
bang for the buck I went with the B-Body gas tank swap. these are efi tanks. the fuel sender is compatible with our stock style gauge readings. the pumps are 240lph which will support up to 600hp in a 3/8" fuel line. as well there 24gal, so you get some extra capacity. HDPE aka plastic construction is lighter and does not attract heat like a metal tank will. and last kicker is they have some awesome baffling in the tank.
you can pick these up at the wrecking yard for mayby $100 probably less now days. worth looking into
1968 Beaumont
post #7 of 15 (permalink) Old Apr 7th, 20, 8:28 AM Thread Starter
Pat
A lot o folks say that if your carb is running good, let it alone, and mine is running fine but I am always looking to tinker and EFI just seems like a good step. I am not looking for big HP gains but would do it simply for the fact that you can just hit the key like a modern car and it fires up and the consistency of the system once its dialed in.
Pats70ss is offline
post #8 of 15 (permalink) Old Apr 7th, 20, 8:57 AM
Have you looked at Edelbrock Pro Flo 4. This is the easiest to tune. Self learning is very fast plus its true MPFI with timing control included.
Pats70ss and Binford like this.
64 Chevelle 496
StevenS is offline
post #9 of 15 (permalink) Old Apr 7th, 20, 9:09 AM
Claude
This is exactly why I bought a Sniper… I am not especially looking for more "hp" but if there is, well good… but the main reason is, like you said "the fact that you can just hit the key like a modern car and it fires up" It'll be a great improvement since my carburetor has no choke on it and it's sometimes requires a little "dancing" on the throttle pedal in the morning.
Claude.
1971 Chevelle SS
toofastforyou is offline
post #10 of 15 (permalink) Old Apr 7th, 20, 9:48 AM Thread Starter
Pat
will look into this one Steve! I like the "easiest to tune part"
Pats70ss is offline
post #11 of 15 (permalink) Old Apr 7th, 20, 9:49 AM Thread Starter
Pat
Claude.
Same here Claude, no choke and do the throttle dance every time I start it. I am ready to embrace new technology..LOL
Pats70ss is offline
post #12 of 15 (permalink) Old Apr 7th, 20, 10:34 AM
does your carb have a choke? gerts rid of the toe-tapping.
post #13 of 15 (permalink) Old Apr 7th, 20, 1:16 PM
Andrew
I just made a detailed post about this topic:
https://www.chevelles.com/forums/89-...i-systems.html
Andrew
Kopfjaeger likes this.
Instagram @projectgattago
Please get in touch for Holley EFI tuning services.
andrewb70 is offline
post #14 of 15 (permalink) Old Apr 10th, 20, 3:11 PM
sam
Pat, the Holley sniper tank with the internal pump is what I used. I left the distributor alone, as the car ran great before. Turning the key after it sat for the winter and having it fire up and stay running is great. I actually picked up a laptop to fine tune and bought the connector to use it, and have had no reason to mess with it yet. Car is more responsive runs cleaner. And I thought it already ran great with that Quick fuel you have!
1967 Royal Plum, 434BB, AFR Heads, 3.90 gears, New Chris Straub Hyd Roller!, 200r4
scalise71 is offline
post #15 of 15 (permalink) Old Apr 10th, 20, 4:20 PM Thread Starter
Pat
Hey Sam,
That is why I remain intrigued, the Quick Fuel you sold me does work great, car has never run better but then I hear you say how EFI is even better and it keeps me thinking about it
Dakota Digital dash is up first though..
Hope your staying safe up there.
Pats70ss is offline
