Holley Sniper issue - Chevelle Tech
 5Likes
post #1 of 25 (permalink) Old Nov 17th, 19, 12:30 AM Thread Starter
Kurt
Holley Sniper issue
Sniper lovers.... I need help ....
I just got my '66 finished and home last week ....
Driving it with the "out of the box" 1:1 throttle linkage,
it's just about impossible to launch it ....Canít feather
the throttle for a tire saving take off .... (TKO 600)
Runs great after that ....
I bought a progressive link that brings the secondaries in
after the primaries are open +-40% ....
Problem is, the vacuum ports are fed by the secondaries...
So, no vacuum until they are open .....But, I can upgrade the
distributor to get rid of the vacuum advance ....
But, the question is, where do I get vacuum for the brake booster ??
1966 Black/Red SS coupe .....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
13/12 4 wheel disc brakes
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #2 of 25 (permalink) Old Nov 17th, 19, 1:27 AM
Justin
I have the progressive linkage and have my brake booster running to the back of my sniper. Everything works just fine
JF74chevelle is offline
post #3 of 25 (permalink) Old Nov 17th, 19, 8:38 AM
Allen
Re: Holley Sniper issue
Interesting, just goes to show that different set-ups and people want different things. There is a recent thread where someone is converting the Edelbrock PF from progressive to 1 to 1 because the progressive didn't have the throttle response he was used to/wanted.
As for vacuum, if the provided ports don't work you could use a spacer with a port or use a port directly from the intake. Good time to switch to a controlled distributor (assuming the Sniper has provisions for it), I went with the GM small cap controlled by my Holley Terminator. It's handy to change timing and curve with a few key strokes; really lets you dial in what the car wants with minimal effort.
Blown1932 is offline
post #4 of 25 (permalink) Old Nov 17th, 19, 9:49 AM
Claude
Do you mean that it has too much throttle response Funny 'cause most guys are hoping to have more! Öbut maybe it's more "touchy" with a manual transmission, I dunno.
1971 Chevelle SS
toofastforyou is offline
post #5 of 25 (permalink) Old Nov 17th, 19, 11:20 AM Thread Starter
Kurt
Thanx for the input .... Yes, itís the "touchiness" that makes the car hard to get off the line ...
Since Justin didnít have a problem, Iíll go ahead and install the link, tell the hand-held I did
it, and see what happens ...
Blown1932 likes this.
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #6 of 25 (permalink) Old Nov 17th, 19, 11:51 AM
Justin
It’s not necessarily the throttle response for me, it was that the pedal was so stiff, it was hard to gauge how much throttle to give it. especially with a manual car.
thebeast likes this.
post #7 of 25 (permalink) Old Nov 17th, 19, 2:21 PM Thread Starter
Kurt
Originally Posted by JF74chevelle View Post
Itís not necessarily the throttle response for me, it was that the pedal was so stiff, it was hard to gauge how much throttle to give it. especially with a manual car.
I need to clarify..... Mine is too stiff, also ..... "touchiness" was the wrong description....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #8 of 25 (permalink) Old Nov 17th, 19, 10:10 PM
Jason
For a stiff, touchy pedal try putting the throttle cable ball higher up on the linkage to make it easier to move.
-SS454- likes this.
69 Chevelle SS
Budget 454, 10.4:1, small valve 781's, Engle hyd cam 244/260 @ .050, .560/.570 lift ICL/LSA 108/108, Performer RPM w/ 750DP
1.75 Dynomax coated headers, Full 3" exhaust with 17665 Super Turbos
700R4 w/10" 3500, 12 Bolt 3.73's, 275/60-15 DOT Hoosiers, 3650lbs without me
Best time: 11.96 @ 111, 60' 1.65 (6-20-2014)
JB SS 396 is offline
post #9 of 25 (permalink) Old Nov 17th, 19, 10:25 PM Thread Starter
Kurt
Iím using a rod instead of a cable .... itís hooked as high as itíll go ...
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
post #10 of 25 (permalink) Old Nov 18th, 19, 12:57 AM
Justin
Raise up the throttle linkage, that helped a ton too
post #11 of 25 (permalink) Old Nov 18th, 19, 8:46 AM
Jimmy
This will fix the stiff throttle linkage. https://www.efisystempro.com/sniper/...ter-lever-1952
Twin Turbo 400 SBC 748 RWHP.
1250 Super Sniper EFI, Turbo 400.
Yukon0724 is offline
post #12 of 25 (permalink) Old Nov 18th, 19, 9:21 AM
This will do the trick. Make sure you follow the setup instructions. Easy to install but you need to use the handheld and set the throttle position telling the sniper exactly what throttle position the secondaries start to open with the link installed.
travisch is offline
post #13 of 25 (permalink) Old Nov 18th, 19, 11:03 AM
That was me. I decided not to convert the Edelbrock progressive linkage throttle body to 1:1 throttle linkage. I used the FiTech Go Port 1:1 throttle linkage throttle body I had after modifying it so that it worked with the sensors Edelbrock uses. It's a 900cfm throttle body. Car runs great.
I also lightened up the spring pressure on the throttle body throttle linkage. It's easy to modulate throttle input with less spring pressure. I don't feather my starts with a little 400HP SBC and an automatic unless the roads are wet. Darn one legged rear end and my cheap tires don't hook up that well on a wet road.
Brake booster port is below the throttle blades on the Sniper and full time manifold vacuum. Ported vacuum for a vacuum advance is above the blades. There should be another small full time vacuum port on the Sniper.
'65 Chev El Camino
SBC350/Maybe 400HP @ crank, 700R4
Edelbrock Pro-Flo 4 4150 MPFI
'67 P-11 Norton
Schwany is offline
post #14 of 25 (permalink) Old Nov 19th, 19, 12:06 PM
sam
When I first installed my sniper, it did the same thing. Drive it for a while and allow it to tune and it will calm down. Mine has, without any modification.
1967 Royal Plum, 434BB, AFR Heads, 3.90 gears, New Chris Straub Hyd Roller!, 200r4
scalise71 is offline
post #15 of 25 (permalink) Old Nov 19th, 19, 12:28 PM Thread Starter
Kurt
Itís almost impossible to drive it now, being a clutch car ....
A rear-ender waiting to happen ....
I have a throttle extension coming ..... Iím trying that
first, before going to progressive ....
402 BBC
Holley Sniper EFI
Long tube headers
Tremec TKO 600
Truetrac 3:73 Posi
Classic a/c
Dakota VHX gages
thebeast is offline
