68-72 el camino PROFLOW4 AND EFI TANK INSTALL - Chevelle Tech
 17Likes
post #1 of 74 (permalink) Old Nov 8th, 19, 6:22 PM Thread Starter
PROFLO-4 AND EFI TANK INSTALL 71 El camino SS 454
Thread to commence with the installation of a TANKS Inc EFI fuel tank and GP4 pump as well as edlebrock PF4 system.
StevenS, Blown1932 and 69Chvll like this.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
Strange 12bolt w/4.10
1971ss454Elco is offline
post #2 of 74 (permalink) Old Nov 8th, 19, 8:17 PM
Re: 68-72 el camino PROFLOW4 AND EFI TANK INSTALL
Use caution with the Tanks, Inc "armless" cylinder style of sending unit if you chose that style of sender. They recently had to send me a new one under warranty because it is electrically delicate if you accidentally hook it up wrong. It's all good now but dropping that tank and redoing it all again was something I would have liked to avoid.
B52bombardier1 is offline
post #3 of 74 (permalink) Old Nov 11th, 19, 12:10 PM Thread Starter
Heres the car Im doing the swap to.
Kit should be in today and Ill start pictures hopefully this week.
Name:	ELCO4 12-3-18.jpg
carpoor likes this.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #4 of 74 (permalink) Old Nov 27th, 19, 7:12 PM Thread Starter
First of many pics.
Tanks inc tank arrived today as did the pf4 system. I can tell right now that the pass side fuel rail hookup isnt going to fit behind the 96-2000 GM serp belt system. Im going to have to move the cross over to the front and inlet with sensor to back but we shall see when I test fit.
Name:	TANK INSTALL1.jpg
ID:	609388   Click image for larger version
Name:	TANK INSTALL2.jpg
ID:	609390   Click image for larger version
Name:	TANK INSTALL3.jpg
ID:	609392   Click image for larger version
Name:	TANK INSTALL4.jpg
Name:	TANK INSTALL5.jpg
ID:	609396   Click image for larger version
Name:	TANK INSTALL6.jpg
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #5 of 74 (permalink) Old Nov 27th, 19, 7:21 PM Thread Starter
I saw that and the instructions are kind of vague as well.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #6 of 74 (permalink) Old Dec 2nd, 19, 4:53 PM Thread Starter
In case no one has figured it out. When you order an EFI tank it comes with baffling.
Also,
when using a OEM style tank and setting up the pump assembly notice that the wires wont come through directly and could get pinched as you pull them through the top to take out slack so be careful. You wouldn't have this issue as bad with a deeper tank.
Name:	TANK INSTALL9.jpg
ID:	609804   Click image for larger version
Name:	TANK INSTALL8.jpg
ID:	609806   Click image for larger version
Name:	TANK INSTALL7.jpg
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #7 of 74 (permalink) Old Dec 10th, 19, 11:42 AM Thread Starter
Im going all out and not scrimping on terminations
Name:	TANK INSTALL10.jpg
ID:	610388   Click image for larger version
Name:	TANK INSTALL11.jpg
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #8 of 74 (permalink) Old Dec 12th, 19, 10:53 AM
I hard wired mine in. Where do you find those connectors? I want to start using them for other things in my car including rewiring the fuel pump. I think I need different crimpers for them though right?
I can say my set up with different from Tanks Inc.
I have the 400lph pump and it has been awesome. I do have the arm style sending unit and it hasn't given any issues either, I was surprised it was accurate.
tacomatrd is offline
post #9 of 74 (permalink) Old Dec 12th, 19, 2:34 PM Thread Starter
electrical connections are from PICO. Yes you need a crimp tool but those are cheap at harbor freight or you can get them a PICO as well on line. Many PICO items are at car part house like car quest but i have the luxury of being right next door to the PICO factory here in Oregon and I know the owner.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #10 of 74 (permalink) Old Dec 12th, 19, 2:43 PM
Oh nice!
I have MSD crimpers, I wonder if I can use a different set of dies.
I will take a look.
post #11 of 74 (permalink) Old Dec 12th, 19, 2:57 PM
Troy
You can buy those connectors on Amazon,they're called weatherpack. Available in many different kits.
66 CHEVELLE
senna is offline
post #12 of 74 (permalink) Old Dec 13th, 19, 12:36 PM Thread Starter
correct. They are only good to about 10 awg wire and thats pushing it for those little clamps to grab on the male part of the weatherpack bullets. I wouldn't recommend anything bigger than 12 awg.
senna likes this.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #13 of 74 (permalink) Old Dec 13th, 19, 3:49 PM
Les
I installed the same tank/pump in my '69 elco with plans to go to efi someday in the future, looks like someday will now be as soon as the 383 is back from the machine shop rather than waiting. Planning on the Pro Flo 4 XT instead of the Pro Flo curious as to your thoughts on the two different systems. Also did you use the vent built into the tank or the one on the pump?
trmn8r is offline
post #14 of 74 (permalink) Old Dec 13th, 19, 3:57 PM
It is up to you what and what you prefer, I do believe the xt will require a cowl hood. I have one in mine.
Also, My vent is built into my pump assembly if I remember correctly.
I like the look of the XT, but to each their own.
post #15 of 74 (permalink) Old Dec 13th, 19, 4:01 PM
Les
you have the XT, and had a cowl hood already or you had to add the cowl hood? looking at it I thought (hoped) it would fit without it, I don't have a cowl hood.
trmn8r is offline
