Holley sniper EFI master or non master kit ? - Chevelle Tech
post #1 of 7 (permalink) Old Sep 11th, 19, 8:54 AM Thread Starter
I am just wondering if its worth the +-200 bucks to get the Holley Sniper master kit over just the regular kit.
If I am also going to buy the fuel injection ready gas tank that comes with the walbro pump.
Just not sure if its worth the extra cash for the fuel line and fittings I realise I will end up with an extra pump. But does the master have a different wire harness to drive the pump or does that come in the regular kit also.
I am just not sure what extra you get in the master kit.
thanks for the help
If it matters it will be going in a 71 GMC sprint.
Joe Smith is offline
post #2 of 7 (permalink) Old Sep 11th, 19, 9:05 AM
Re: Holley sniper EFI master or non master kit ?
Honestly, being in the I.T. field and having dealt with different fuel injection systems over the years, I would go with the master kit!
Save $20 Off $250, $50 Off $500, $100 Off $1,500, $150 Off $2,500 - Use Promo Code: SAVEMORE
https://www.jegs.com/c/Fuel-Carbs-In...0002&langId=-1
ZEN357 is offline
post #3 of 7 (permalink) Old Sep 11th, 19, 11:53 AM
Justin
I used the master kit and it’s pretty good. Are you looking to run timing control in the future? Have you looked at edelbrock proflo 4 set up?
JF74chevelle is offline
post #4 of 7 (permalink) Old Sep 11th, 19, 12:00 PM Thread Starter
I am changing over due to a dead carb. I am not a carb guy and don't want to sink cash into one. As far as timing control at this time not at all.
fairly sure I am going with the holley set up what makes the edelbrock one better at +500 bucks ?
Originally Posted by JF74chevelle View Post
I used the master kit and itís pretty good. Are you looking to run timing control in the future? Have you looked at edelbrock proflo 4 set up?
post #5 of 7 (permalink) Old Sep 11th, 19, 1:27 PM
If you must, proflo 4👍
yanniziomas is offline
post #6 of 7 (permalink) Old Sep 11th, 19, 4:06 PM
Justin
Coming from a sniper user, I’d go with the pro flo4.
post #7 of 7 (permalink) Old Sep 15th, 19, 4:51 AM
sam
The master comes with the external pump. If you are getting the tanks and pump separately then you wonít need the master. You will have to get your hose and filter and 1/4 not fittings separately though. I bought the master first, then decided I wanted the sniper tank, so I ended up with extra parts.
1967 Royal Plum, 434BB, AFR Heads, 3.90 gears, New Chris Straub Hyd Roller!, 200r4
scalise71 is offline
