Sniper surging all of a sudden - Chevelle Tech
post #1 of 30 (permalink) Old Jun 17th, 19, 8:19 PM Thread Starter
sam
I just installed a new sniper system, have put about 150 miles on it. It just started surging both in gear and in park. It revs and idles up and down. Map and IAC #s are all over. Map up and down into the 50ís, IAC goes from zero and blips in the 40ís and back. What could have happened? Any ideas?
1967 Royal Plum, 434BB, AFR Heads, 3.90 gears, New Chris Straub Hyd Roller!, 200r4
scalise71 is offline
post #2 of 30 (permalink) Old Jun 17th, 19, 9:01 PM
Re: Sniper surging all of a sudden
Vacuum leak?
Peewee0413 is offline
post #3 of 30 (permalink) Old Jun 17th, 19, 9:02 PM
AFR all over the place?
post #4 of 30 (permalink) Old Jun 17th, 19, 9:03 PM Thread Starter
sam
No AFR is adjusting as it has been
post #5 of 30 (permalink) Old Jun 17th, 19, 9:07 PM
I'd check for disconnected hoses. Usually the most likey cause for surges. If it's missing I'd check timing then plugs/wires if no hose is off.
post #6 of 30 (permalink) Old Jun 17th, 19, 9:26 PM Thread Starter
sam
PCV is only hose I have and itís intact
post #7 of 30 (permalink) Old Jun 17th, 19, 9:55 PM
Bernard
Check the EFI studs. Are they down tight?
burn6si is offline
post #8 of 30 (permalink) Old Jun 17th, 19, 9:58 PM Thread Starter
sam
I checked them and they were pretty tight, snugged them more, and still did it. This was one of the first things I tried. I appreciate the ideas so far.
post #9 of 30 (permalink) Old Jun 17th, 19, 10:36 PM
Well reset it and see if it runs better. Have you messed with settings recently? If it still surges after resetting then its mechanical.
post #10 of 30 (permalink) Old Jun 18th, 19, 6:33 AM Thread Starter
sam
I havenít messed with any settings, because it was running great. I just had it idling after taking a ride, and I was reading up on the IAC because I have had a whistling under acceleration that I was going to try to work on. How do I reset the system?
post #11 of 30 (permalink) Old Jun 18th, 19, 7:43 AM
Whistle under acceleration???? Probably a vacuum leak since there an idle problem with the sound. Dont reset it. Find the vacuum leak. Lol
post #12 of 30 (permalink) Old Jun 18th, 19, 8:12 AM Thread Starter
sam
I will look for a leak but info on the sniper I have seen, suggests that the whistle will sometimes self tune out, and or is an IAC adjustment as the IAC acts at kind of a (controlled vacuum leak) I just checked all ports on the TBI and the two small ones are capped. The PCV line is tight. when I turn on the key, IAC reads 72 with car off.
post #13 of 30 (permalink) Old Jun 18th, 19, 8:44 AM
Check fuel pressure while it is happening. Also check voltage at fuel pump while it is happening.
Pioneer4x4 is offline
post #14 of 30 (permalink) Old Jun 18th, 19, 8:57 AM
I agree. Poor idle can sometimes cause IAC to open and could whistle. Sure IAC isn't closed during acceleration.
post #15 of 30 (permalink) Old Jun 18th, 19, 10:44 AM Thread Starter
sam
I adjusted the IAC just now with the car warmed up, the map is still in the 50ís. Car was in the high 180s for temps when I had the issues. I didnít notice any surges at idle on cold start or when warmed up in the 160s today.
