How to tune Fitech lean to rich spot? - Chevelle Tech
 3Likes
  • 2 Post By Schwany
  • 1 Post By -SS454-
post #1 of 14 (permalink) Old Mar 5th, 19, 2:32 PM Thread Starter
Hi all
New member but an old time reader to this forum.
Don't have a Chevelle but do have a sbc 350 with Fitech 600 power adder installed in a 1983 full size Jimmy.
Located an ocean away from Detroit but love the feel of an old V8.
Well, enough about me.
I built my truck over 8 years period, and now it's time to finally tune my Fitech.
I need your guys help with what parameters I should change to solve 2 problems:
1. Get rid of the rich spot I get (mostly comes after a momentary lean spot)
2. Get rid of the lean spot at idle (while deaccelerating)
I'm attaching a few screen captures of a log from a drive I did yesterday.
Please ask questions, will try to answer them all.
ID:	588102   Click image for larger version
ID:	588104   Click image for larger version
ID:	588106   Click image for larger version
rob_isr is offline
post #2 of 14 (permalink) Old Mar 5th, 19, 4:42 PM
Ken
Re: How to tune Fitech lean to rich spot?
You might try this site:
https://fitechefituning.com/
Look through the existing posts, or post your question. Austin, who runs the site is usually quick to answer.
67 Chevelle Malibu, ZZ4 350 crate engine, TH350, FiTech EFI, Vintage Air, Dakota HDX dash, FlowMaster exhaust,
17" Rally style wheels, Redline tires
darksky is offline
post #3 of 14 (permalink) Old Mar 5th, 19, 4:46 PM
Justin
I don’t have a fitech I have a sniper, but I agree with the above that the best thing you can do if get on a fitech specific forum and ask for help there. I get my Holley sniper help from the Holley forums and it’s great
JF74chevelle is offline
post #4 of 14 (permalink) Old Mar 5th, 19, 5:00 PM Thread Starter
Thanks I'll try to post there
rob_isr is offline
post #5 of 14 (permalink) Old Mar 5th, 19, 5:52 PM
Lean to rich bog can be addressed with 4 parameters in the Accel Pump menu in the Go EFI Pro Tuning menus. The fix is counterintuitive. Don't dwell on it.
Accel Pump for typical easing into it throttle use
Fast Accel for quick throttle use, like WOT from a stop, or quick half throttle from a stop, or both of those while cruising.
dTPS Acc Gain for a general gain in fuel used
dTPS Acc Max to limit the maximum gain
I'll give you some numbers to play with. You may have to back off on them depending on your intake, heads, and exhaust. If you don't notice any change with the numbers I'm providing, you have other problems that need to be addressed. BTW, you can band aid it doing exactly the opposite of what I'm suggesting by pulling fuel, but your motor won't make as much power. I've done it both ways. More Accel pump works best when the numbers are right. You are trying to kill the lean tip in, which is what causes the over rich correction.
Plug in these numbers.
Accel Pump 20F 11.7
Accel Pump 65F 25
Accel Pump 170F 55.5
Fast Accel 20F 13.3
Fast Accel 65F 25
Fast Accel 170F 59.4
dTPS Acc Gain 147.7
dTPS Acc Max 151.6
Don't lean your Idle AFR out too much. Stoich for pump gas with 10% Ethanol is an AFR of 14.08. Stoich for straight gas is an AFR of 14.68. My motor likes 13.6, but it breaths funny.
For ultra fine tuning you can modify the duration of the pump shot with the Accel Decay and Fast Decay parameters.
-SS454- and Camaro_fever68 like this.
'65 Chev El Camino
350/400+HP, 700R4
Edelbrock Pro-Flo 4 MPFI
'68 P-11 Norton
Schwany is offline
post #6 of 14 (permalink) Old Mar 5th, 19, 6:13 PM
you may find this helpful.
Schwany likes this.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #7 of 14 (permalink) Old Mar 5th, 19, 6:35 PM
That video is helpful for anyone getting started with the joys of FiTech tuning. Cool to see someone taking the time to describe the typical things that need to be addressed if the system doesn't work out of the box.
Limiting Fuel Trim Max in the AFR Closed Loop section is important. I forgot about it.
Thanks for the reminder
'65 Chev El Camino
350/400+HP, 700R4
'68 P-11 Norton
Schwany is offline
post #8 of 14 (permalink) Old Mar 6th, 19, 8:39 AM
Todd
From the data logging it looks like your fuel pump is faulty or the fuel pump wire from the system has a bare spot. Do you have a FP gauge on the inlet to watch as you manually rev the motor to see if it spikes hard or if it might be dancing around at idle?
91c1500sleeper is offline
post #9 of 14 (permalink) Old Mar 6th, 19, 11:08 AM Thread Starter
Thanks for all the good advices, I will try them on Friday morning and let you know how it went.
Regarding the fuel pressure gauge, No, I don't have one.
When I was running carb I used to have but that was for low pressure.
The pump in the fuel tank is new and should be fine (if wiring really is ok)
rob_isr is offline
post #10 of 14 (permalink) Old Mar 6th, 19, 2:42 PM
Todd
The first walbro pump I installed with the system was faulty out of the box and it took me a while to figure it out with a gauge on the inlet. It should hold a steady 58psi of fuel pressure at the gauge and go up as needed.
post #11 of 14 (permalink) Old Mar 6th, 19, 3:19 PM Thread Starter
I'm using the Holley In-Tank RetroFit Fuel Module-Returnless Style with the Hydramat, same as in this link:
https://www.holley.com/products/fuel...e/parts/12-131
rob_isr is offline
post #12 of 14 (permalink) Old Mar 8th, 19, 4:29 AM Thread Starter
Went for drive
Changed one parameter at a time and logged the ride (10 different logs in total).
Honestly, I don't think any of the changes I did had made any improvement.
I'm starting to give up...
rob_isr is offline
post #13 of 14 (permalink) Old Mar 8th, 19, 8:23 AM
Todd
Been there and done it man! It does suck when the system won't cooperate. I do know that the system needs a constant 58 psi at idle with no fluctuating. A good tach signal and some good grounds. I got to a point that I just drove it the way it was for a few years. Then when I swapped the auto out for a manual the system went crazy and would not cooperate. I ended up removing it and putting the carb back on and sold the fitech. The carb works better for me. I had the base 400 horse system as well. I wouldn't give up just yet. The giant thread here has alot of good tips to hopefully get your system straightened out.
post #14 of 14 (permalink) Old Mar 8th, 19, 11:35 AM
The default numbers for the parameters are in the default V8 calibration file in case you need to write the calibration to the ECU to change back to the defaults before you put it up for sale.
Both the FiTech Go EFI 4 600HP and Go Port systems work for me, and I'm not shy about changing parameter values in mass like a lot of people are. I know what the parameters do though, which is why I made the bold suggestions. Those numbers work for me, but every motor configuration responds differently to the tune.
Most likely there is something off with your install, if you can't make it work. For example, intake leaks, exhaust leaks near the O2 sensor, poor electrical system, failing ignition parts, wrong cam profile, clogged fuel filters, bad or incorrect fuel pump, poor condition of the engine, and the list goes on. A carburetor will run on just about anything. EFI not so much.
'65 Chev El Camino
350/400+HP, 700R4
'68 P-11 Norton
Schwany is offline
FiTech and the Go Port road less traveled Schwany EFI 48 Dec 8th, 17 1:03 PM
FiTech 4 600HP and SBC tune to poke at (long) Schwany EFI 17 Sep 29th, 17 9:10 PM
tuners Philip LSx Engine 26 Sep 17th, 17 11:35 AM
Going LEAN at WOT....Dragstrip Test & Tune datalogs rel3rd EFI 122 Apr 11th, 17 10:50 PM
Fitech drag strip accel pump tuning - kinda long NakedCamaro EFI 12 Apr 11th, 17 4:43 PM
