holley sniper - Chevelle Tech
 3Likes
  • 1 Post By timjus
  • 1 Post By 73Eldo
  • 1 Post By modern malibu
post #1 of 8 (permalink) Old Jan 24th, 19, 11:08 PM Thread Starter
holley sniper
i purchased a holley sniper efi system for my 1970 el camino ss396, came with the distributor, fuel pump for gas tank and unit , i hooked everything up i thought was correct and it starts fine but i cant shut it off , i have to unplug unit near box for it toturn off, i ran the red wire to ign terminal on fusebox cant figure it out, otherwise it runs great
tom c is offline
post #2 of 8 (permalink) Old Jan 24th, 19, 11:27 PM
Timo
Re: holley sniper
alternator back feeding to your ignition circuit?
needs a light or diode to alternator exciter wire
tom c likes this.
timjus is offline
post #3 of 8 (permalink) Old Jan 25th, 19, 9:32 AM
Tj
Re: holley sniper
That is the same direction I was thinking. Stock alternator and external regulator? Or has it been 'upgraded' at some point?
What was the previous ignition system? Stock or that too had been 'upgraded'.
And were those upgrades done by you or someone else? Lot of variables there to start with.
tom c likes this.
73Eldo is offline
post #4 of 8 (permalink) Old Jan 25th, 19, 10:16 AM
Mark
Re: holley sniper
If there are any relays in the unit, make sure the #30 post goes to a battery only source and not to ignition terminal on fuse block. This will prevent any voltage feedback into the ignition circuit when the magnetic field collapses in the relay.
tom c likes this.
modern malibu is offline
post #5 of 8 (permalink) Old Jan 27th, 19, 10:02 PM Thread Starter
Re: holley sniper
everything else is stock, my friend helped me on it
tom c is offline
post #6 of 8 (permalink) Old Jan 27th, 19, 10:04 PM Thread Starter
Re: holley sniper
ok , heck i wouldnt know where to start on that stuff, everything on car is stock
tom c is offline
post #7 of 8 (permalink) Old Jan 27th, 19, 10:05 PM Thread Starter
Re: holley sniper
ok i will try that ty
tom c is offline
post #8 of 8 (permalink) Old Feb 5th, 19, 8:50 PM
Re: holley sniper
try this, easier.
https://www.ebay.com/i/191103912421?chn=ps
This Thread is more than 424 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
